  1. ive been using vdub to cut the audio out and encode using tmpgenc but the audio slowly goes out of sync by the end of the film, can anyone help?
    thanx
    danny
  2. is the audio in sync before incoding (try vieing in media player), if they are ok then it could be the frame rate, load up VirtualDub and click file: file information, and see if its pal (25fps) ntsc film (23.976) or ntsc (29)
    then when encoding in tmpenc select the correct template in wizard
    also have a look at my document i wrote that explains this
    www.data-uca.150m.com/vcdencoding.doc, its only a word doc i wrote for a friend and some others have said it really helped, any question post here and i'll try to help
