In recordnow max do i need to select the audio ts folder even if it is empty as well as the video ts folder
just burned a movie without the audio ts folder what have i lost\ormissed out
i will select it next time but the movie seems to play fine
Its better to have the empty folder there for compatablity with all stand alone dvd players
Although i have read it will play without it on some
I always add it in
ok thanks it was a mistake (first time backup) will remember to add it in future
I never burn with the Audio_ts folder and in over 100 DVD's they all play in the three players I have at home plus the four players my family members have.
Also I should add if you look at the files on an original DVD movie I bet you will see that half of them don't have an Audio_ts folder. -
If there is nothing in it what is it for
or has it sometimes got something in it .. -
It's for making Audio DVDs (vs. the normal Video DVDs). The problem is that pretty much no one us making audio DVDs. However, it's part of the DVD standard so it's generated by most authoring programs and on most DVDs (although I have seen like 2-3 DVDs without one).
You don't really need it. There might exist some DVD players that won't work without an AUDIO_TS folder, but I doubt it
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
adding dts audio stream to DVD folder
By medo_256 in forum Newbie / General discussionsReplies: 56Last Post: 6th Jun 2010, 06:54 -
rip dvd folder and keep both audio channels ???
By hulinning in forum DVD RippingReplies: 12Last Post: 16th Feb 2009, 11:43
