buddies i backed up two dvds using instantcopy, so far so good except for the lengthy process. one question is which audio track shall i keep when it comes to customize file? there are quite a few each in the size of hundreds of mbs that i really want to save it for the video.
the IC help says "In order to create DVDs that can be played on DVD players, "PCM" or "AC3" must be available as audio tracks.Other audio tracks can be deactivated.The greater the quantity of "deactivated" audio data, the higher the quality of the video picture will be."
there are several AC3 audio tracks, can i keep one and disactivate the rest? if yes, which one to choose?
Go to this link, all will be revealed!! Enjoy!
Celsis
http://www.mrbass.org/instantcopy/We all gotta start somewhere!!!!
Need advice on repairing audio tracks on a video
By Jesse_Bolt in forum AudioReplies: 11Last Post: 18th Sep 2011, 10:15 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20
