He's using DV AVI which is 720x480 and about 12GB per hour, not uncompressed AVI.Something's wrong here: 12 gigs of AVI file for 2 hours means you've captured a screen size around 320x240 which is a VCD type of resolution. DVD is 720x480 and 12 gigs of avi would only give you approx 12 to 20 minutes of this type of resolution.
You may be right about the audio though since some programs may not let you use MP2 audio with NTSC. To get the audio down to a reasonable size and not have that problem save the audio to a seperate wav file and convert it to AC3.
Results 31 to 32 of 32
That's a great compression rate; you learn something new every dayOriginally Posted by Bondiablo
Pobody's Nerfect
VHS to PC for conversion to DVD
By EJ8 in forum Capturing and VCRReplies: 6Last Post: 15th Jun 2009, 20:49 -
VHS to DVD conversion
By gallootjs in forum MacReplies: 7Last Post: 7th Mar 2008, 08:44 -
By elia12978 in forum Capturing and VCRReplies: 16Last Post: 13th Jan 2008, 17:42 -
VHS to DVD conversion help
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 2nd Nov 2007, 19:24 -
about VHS to DVD conversion
By hanamachi in forum Capturing and VCRReplies: 4Last Post: 16th Oct 2007, 16:32
