Ok, I've got the endoding thing down, and able to fit on one disk. Problem though, is the movie speeds up and slows down throughout the movie, but the audio stays with it. Bigger problem, is that it makes cracking and popping noises, and I can't figure out how to eliminate it. Any help????
Try going through the guid again and check for any visible mistakes and possible reading mistakes that you may have done. Also, have you defragged you drives lately?
If everything is infinite then nothing is definite. -
What program/s and settings are you using?
The video actually slows down and speeds up? That's not right, there's some problem there (prehaps with the framerate). As for the audio (assuming you are using TMPGenc) try using tooLame to encode your audio instead of the TMPGenc's internal engine. -
I forgot to add, when you're making it fit onto one CD, change the bitrate to constant instead of variable, that may fix the problem...
Let me ask this. I've had some problems with my cd writer. I have a Teac 8X. Ever since I've installed Win XP, I can't get it to write any faster than 1X. Does anyone think that this could be a problem?
Unless the movie only speeds up and slows down after it has been burned onto a CD, then I don't think that is the problem. Though, I would be concerned about that nonetheless.
Ok, check this out. I re-encoded it, and it seems like everything is ok on my computer. I'm assuming that either the 1X speed that I burn at, or the Nero I use is corrupting it. Any ideas? A different way to convert to VCD first, and burn with WinXP? or another burn program???
.Mov Conversion Problems - Audio
By Jralph in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 09:09 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 19:35 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 03:13 -
Problems with audio conversion from RM to MP4
By spadgham in forum ffmpegX general discussionReplies: 2Last Post: 10th Sep 2008, 17:24 -
WMV Conversion to Xvid - Audio Synch Problems Again
By TonyRomo1227 in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 17:32
