  1. Hi guys,
    First thing I want to do is say thanks, you guys have really helped me a lot.
    Second, Why is InstantCopy so slow? When I convert my movies to SVCD it takes about 30 minutes to rip the files off the DVD, about 2 hours to convert a 2 hour movie, 5 minutes to demux, 5 minutes to cut, and 3 minutes to burn. All total it is about 2 hours and 45 minutes from start to finish.
    Using InstantCopy takes 3 hours just for the conversion. Yes there is less steps, rip (30 minutes), convert (3+ hours), and burn (25-30 minutes) but it is way slower.
    Am I doing something wrong? Is there a setting I need to enable?
    Computer Config:
    AMD XP1900+
    MSI KT3 Ultra2
    512 Megs PC2700 DDR
    Toshiba M1612 DVD-Rom
    Pioneer DVR-105 DVD-RW
    Lite-on 48x12x48 CD-RW
    2 - 60 gig IBM 75GXP's in RAID 0
    PNY G4 TI4200
    Enermax 350W
    Software:
    WinXP Home
    InstantCopy 7.0.0.91
    DVD Decryptor 3.1.4.0
    Please Help the Newbie
  2. you aren't doing anything wrong, if you read the instant copy thread you
    will see that is how long it takes for this program, give or take a few minutes. That's just the nature of the program. Since you are doing SVCD's, you should think about how long DVD2SVCD along with TMPGencPlus would take and count your blessings. If you want something faster and have a DVD burner, then go with DVD2ONE. People who care so much about speed love that program. If you don't have a DVD BURNER, then you'll just have to live with the 3+ hours for now.
