  1. I use virtuel dub to frame serve subtitles to TMPGEnc, but when I open the .vdr file ( or try to) in TMPGEnc I get the message file not supportet. I have follow the guide on this side and given the directshow multimedia file reader a higher priority (1 or 2) but still getting an error about not supportet file. It is possible for me to open the .avi file both as video and audio input in TMPGEnc. I can open both the .avi file and .srt file (subtitle) in BS Player so I have all the codecs needed installed. The file I want to encode to .mpg (vcd) is an Divx with ac3 audio.
    Anyone please help.
  2. Have you installed the handler from virtualdub?
    have you chosen these VFAPI setts? cuz, you sayd, direct show reader on a higher priority...
  3. I have installed the handler from virtuel dub and tried the vfapi settings as you show, but still the same problem.
  4. you installed the nimo codec pack?
  5. I have installed Nimo Codec pack, but still the same problem.
