When I try to convert an avi to mpg w/ TMPGEnc ver.j, I loose the video. I can open the mpg when finished the sound works fine, but have no picture. Please help.
I think, you have select Stream type - System (Audio only). Try Stream type - System (Video + Audio).
thanks, but I did have that option chosen thats why I can't figure it out whats wrong.
Can you play the file in media player with both video/sound?
When you preview the file in TMPGenc can you see the picture? For example, under source range.
Have your tried frameserving the file to TMPGenc with avisynth. I've had a few captured AVIs that played fine in media player but came up blank in TMPGenc. Framing serving with AVIsynth allowed TMPGenc to view them (have no idea why).
http://www.math.berkeley.edu/~benrg/avisynth-tutorial.html
the only command you'll really need to use is:
AVISource("d:\capture.avi" -
Whenever I try to open the file I created, it says... "AVISource: failed to decompress frame 0 (error -100)"
Problems converting video files .MOD to anything
By daka in forum LinuxReplies: 0Last Post: 24th Dec 2010, 13:16 -
Canon HF11 converting video footage problems
By AP joe in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 4th Apr 2009, 20:30 -
Problems converting MP4 video file to DVD.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 6th Oct 2008, 18:26 -
New to Video converting (ffmpegx) and having RM problems
By fostersdf in forum ffmpegX general discussionReplies: 4Last Post: 6th Sep 2008, 00:15 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 01:24
