now i read somewhea on the how-to a while back but cannot find that same page now...this is wat i'm trying to accomplish...i have alot of anime...i want to squeeze in as much anime as possible onto one dvd...i've successfully turned many divx into mpg/vcd format...but unfortunately only 80 min could be recorded...as i understand from reading the how-to...u can keep the mpg video format and just change audio to from 44k to 48k...that i have done...but yet i still cannot burn onto dvd-r correctly...i'm using nero...have pioneer dvd burner...does anyone have a good write-up on how to put as many divx anime/movies into a dvd-r?
You are going to need to author the VCD's.
www.dvdrhelp.com/vcddvdr.htmMay the force be with you. -
its software where all you do is load your mpeg into the program. it makes a menu so you can click on what movie you want to watch. all you need to do is click burn and thats all you do. just have to make sure the audio is 48000 kps before using the prgram because it change the audio to pcm and that take up alot on space so you won't be able to put as much video onto the dvd. i have the software if you would like to try it. just pm me if you want to try it.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
