HeeeeeeeelP!!!
When I parse the video portion of my movie my DVDMaestro crashes with this error message:
AppName: dvdmaestro.exe AppVer: 2.1.0.0 ModName: mediafile.dll
ModVer: 2.0.0.0 Offset: 0006593c
Sometimes compiling a not complete move helps me but only sometimes.
Unfortunately this way my DVDMaestro cis very unstable.
I have a single P4/2,5 GHz w. 256M RAM and XP and DVDMaestro 2915a
Can anyone help me??
Results 1 to 14 of 14
I use DVD Maestro and have not actually seen this problem before.
What is the file that you are parsing ? Is it Audio or Video. What is the exact format ?
Can you load this file and more importantly play it in other applications ? -
I once had this when importing a (re-encoded) .M2V-file.
I re-encoded the video stream again and then it worked.
MrSnakeSony DRU-500A v1.0d
Toshiba SD-M1302 v1006
Philips DVDR885P v1.7/8 -
My files are DVD compliant video files created by TMPGenc (720x576, 25 fps, max. 30 frames in GOP, I/B/P: 1/4/2 struct).
Scenarist accepts them, but this sw. is so complicated.... -
My initial DVD files were also DVD Video compliant, yet I still had to re-encode them again to solve the problem.
It doesn't matter which soft you used for creating video files, there's always a chance that something can go wrong.
I have a similar problem using spruce up meastro. It gives me a parsing error at 65% of the movie ( GOP out of sequence or something like that ), I do exactly the same with IFOEDIT and it has no problem at all. The point is I can't do the menu and button with IFOEDIT whereas it is much nicer with menus done in Spruce
any ideas please
thank -
if anyones still having this problem i fixed mine by
hexing the Offset: 0006593c of mediafile.cll
change it from "8A" to "8B"
i dont know if its really fixed or just temporary
ill post back anymore info that i have later
MAKE SURE YOU BACKUP THE INTACT MEDIAFILE.DLL FIRST -
was that a GOP size of 30 I saw? Isn't that outside the DVD Specs?
George -
maybe he meant 30 fields
which is 15 frames
but i confermed the above fix with 3 problematic movies
and i havent seen any thing wrong yet -
maybe, but those numbers are "usually" seen with NTSC, and the OP is talking PAL resolutionsOriginally Posted by dmcbudman
George -
I'm just going based off the MainConcept encoder found in Ulead products, and the Standalone Mpeg encoder. It seems to default the GOP to 12 for PAL, and 15 for NTSC (about a half second of each respectively).Originally Posted by Abond
Yes, 15 frame GOP is within PAL parameters, just not sure what the original "30" meant...George -
I guess it is a setting in TMPG which should have a meaning if one want more than 1 I frames in GOP. In the current situation I think it is not effective as 1/4/2 for I/P/B give exactly 15 frames. But who knows what Maestro thinks about this...
About the frames defaults maybe you are right (I never paid attention about the defaults
), but I wouldn't encode 23.976 fps NTSC with more than 12 frames GOP, because after the pulldown they may become more than 36 fields GOP=trouble.
ffmpeg.exe has stopped working error when trying to add asset
By skeet09 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2009, 16:15 -
blank asset menu
By anakin1312 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 06:21 -
DVD authoring fails - 'error in parsing XML'.
By Levina in forum ffmpegX general discussionReplies: 12Last Post: 22nd Mar 2008, 10:10 -
Parsing error
By screenhoofd in forum ffmpegX general discussionReplies: 6Last Post: 6th Oct 2007, 08:17 -
Remove asset button?
By coldracerx in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Aug 2007, 22:13
