Hi,
i got a new Nero Version and it starts always with this fu.... Express.
How can I start the old GUI ??.I try to burn a xsvcd and have to switch
of the compatibility mode.
Thx
Wolle
I couldn't find a way to turn it off either and the manuals on the NERO website have disappeared.
The way I got around it was to uninstall the new version and re-install the old version with the standard interface, then install the new version as an UPGRADE (not a new install) - this retains the perferred interface. -
If you right click on the shortcut and choose properties, the target will see:
"C:\Program Files\Ahead\Nero\nero.exe" /w
The switch "/w" at the end will open Express. Remove it and the standard ui will open.
Hope it helps.
Ash -
Nope, tried that - in fact I run Nero.exe directly - no runtime params - still only comes up as Express without the option to switch to standard mode.
If you look at the bottom next to the 'MORE>>" button, you will see the Nreo button. Select that and you woll be able to switch to the regular mode.
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
Nero Recode's start off pixelated
By 12gage in forum DVD RippingReplies: 0Last Post: 15th Aug 2010, 00:05 -
How do I start?
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Dec 2009, 07:29 -
Nero 7.7.5.1 start burning at 1x!?
By arminio in forum Authoring (DVD)Replies: 23Last Post: 5th Jan 2009, 05:50 -
how configure nero 7 to start up on DVD choices
By zmartha in forum Software PlayingReplies: 4Last Post: 13th Aug 2007, 18:54
