Is this possible?
I used a template from sefty's how to page and it didnt work
Yes.
Well, it depends:
- on the size of the movie (who could have thought that?!
Give us more details on the LENGTH of the movie, the FORMAT you want it to be encoded. THEN, we can answer your question...
(You can find decent quality >2hr movies with size <700Mb... DivX does the magic...)
BeTa -
My suggestion is when size counts, use 2-Pass VBR instead of what Sefy has (CQ_VBR I think).
With 2-pass, you can use the bitrate calculators and get a better idea of what AVG bitrate to use. This THE only way (with off-spec VCD) to insure you don't go over the space on CD.
Plus, you can have a MIN bitrate of 500, and a MAX as high as 2400 (not over if you have a Pioneer), and should result in higher quality. WARNING: IT TAKES TWICE AS LONG.
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 23:19 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
