XVID to a DVD format?
Any idea's
Results 1 to 10 of 10
Why are the best things things in life cost the most money?
Who stole the rest of my Signature, Own up, it was you, yeah you, thats it I am gonna come over there and .......... -
dont forget the fourcc... both should be DIVX
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
OK this is my situation, I have 2 XVID.avi's on my HDD and I want to put them together to make 1 whole film so I loaded up Virtualdub added the 2 files and made 1 long film. Now to burn to a DVD-R I have to convert into MPEG-2 (If I am correct), Now when I load up TMPGEnc-2.510.49.157 and start to encode the whole film I created it freezes after the first 1 second and then if I click on the program I get "Not Resonding"
Any help pleaseWhy are the best things things in life cost the most money?
try to convert each XviD.avi seperately and then merge the two DVD files together....
I tried that and got an error (something pointer operation)
1)Try getting your VFAPI's correct...
https://www.videohelp.com/forum/userguides/119019.php
scroll down a lil'bit
2) is the fourCC of the movie correct?
try this
start fourCC (its a proggie included with the XVID codec)
load the movie (...)
now, both fields should be in DIVX
press aply
try TMPG again
3) try frameserving
https://www.videohelp.com/forum/userguides/87270.php
(again, check the VFAPI setts)Wanne earn something a couple of dollars?
You might have bad frames in your XviD, use VirtualDub to check if you have any bad frames.Originally Posted by JLR
Here's a guide for deleting those bad frames if there are any:
https://www.videohelp.com/forum/userguides/142555.php
Hope That Helps!!!
:P
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17
