Ok what i'm trying to do is put a compliation of svcd files on a dvd-+r![]()
i get the concept with nero where you choose new>svcd>etc.. for the cdr option.. where you can click and drag, what i'm trying to do is the same but this time with a dvd-+r how do i do that cause when you use the dvd option when you choose a recorder with nero the only options you have are dvdrom, dvdcopy, dvdvideo, dvd-rom(boot), dvd-rom(udf), dvd-rom(udf-iso)so which of these dvd setting do i need to use to make one like i'm using the create a svcd with just regular cdr settings, someone please help, i know there is an easy way to do this...
basically all i want to do is click and drag svcd files and be able to put more on a dvd-+r, which has more room than a cdr...that's all if someone knows a setting to use, let me know
It is NOT possible to burn svcd on dvd. You can just copy the svcd mpgs and burn on the dvd but it wont work on most DVD Players(only such with mpeg1/mpeg1 iso playback). To get it to work 100% you must reconvert to dvd
www.dvdrhelp.com/mpeg2tovcd (tmpgenc)
or let moviefactory convert to dvd
https://www.videohelp.com/forum/userguides/139093.php
or you can make a xdvd that requires no video reconverting but it only works on some dvd players
www.dvdrhelp.com/svcddvdr
(and PLEEEEEEEEAAAAAASSE use our forum search, this has been discussed several times).[/b]
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
Cannot read Nero-burned CDR (Vista) on XP
By walter4h in forum ComputerReplies: 4Last Post: 27th Mar 2008, 02:20 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
