I have read a few posts that say RecordNow Max is great for creating a DVD from the Sony DRU500 A, to play on many different DVD players. I have tried the HowTo guide for Nero and DVDWS, with 50% success.
Seeing the great comments on Record Now (for comatibility for multiple players), I decided to download the trial version. But, the manual doesn't say anything about UDV 1.02, 1.05, burning DVDs, or much at all for help.
I am familiar with the concept for Nero per the help guides (Select UDF DVD, Copy directories over, select 1.02), but I don't see anything on this for this program.
Do I just "make a data disk" and copy the 2 directories to teh DVD?
Any help appreciated.
Roger -
YES ditto, as stated above. 50% success with NERO that is about par.
It is all cut and dry, assuming you have a folder VIDEO_TS with DVD compliant files and an empty AUDIO_TS folder choose your recorder and a data project add files and hit the BIG RED button.
An ISO file is done via Image selection choose ISO or ALL FILES and same as above. No need for a 5000 page manual.
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Can RecordNow Max be used to create SVCD's too? Looking at their software package it would appear so. Does anyone use RecordNow Max for discs other than DVD's? I'm currently looking for an alternative to Nero that doesn't involved disc images!
Please stick to the topic. Only DVD HERE. SVCD in the VCD/SVCD authoring forum.
I need a DVR that can record without making a menu page
By khicks in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2010, 17:41 -
Screen doesn't expand to the max of the HDTV width and height.
By wishstar99 in forum ComputerReplies: 11Last Post: 30th Aug 2010, 12:08 -
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 14:09 -
Big Blank DVD'S and thier Burners
By SIRCOOKS in forum ComputerReplies: 11Last Post: 23rd May 2008, 11:34 -
Pioneer DVR-531 TVGOS menu won't even come up anymore/can't manual record
By ibhay in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Jun 2007, 19:34
