hi i was wondering if someone could help me out with something i bought ati tv wonder pci to convert vhs to vcd but i have no clue where to start i installed all the software already and its all installed my vcr is a ge and its conected to the ati by rca hook ups my operation system is windows me i can get the movie to play but i dont know what to do after that.Also theres these lines going threw the middle of the picture its not my tape and its not the vcr so how can i fix that? please help if you can.
thanks
Jenna
Always start at the Newbie Guides. Then since you want to "capture" your VHS movies into your computer read up on the Capture section. Then since you may want to convert this captured video into VCD format, read the Convert section. Then, since you will have to author the video onto a CD, read the guides in Author.
Hello. -
I figured out one thing when you record the lines dont show but its all in mp2 format and im just reading up on how to convert that.
Jenna
thanks for the reply!!!!!
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
