i want to be able to capture some footage off of my Playstation 2, make a video, and put it on the web so what would i need to do that. i understand i need a capture card but i have no idea of what to look for, someone recommended a Matrox RT.X10 and it seems good and i'm thinking of getting it but i have no knowledge whatsoever about Videocards i wouldn't know how to install it or undertsand it for that matter, is the Matrox RT.X10 any good. i just want a very good capture card so i can hook up my Playstation 2 to it and capture some footage and put it on the web. i need one around the $600.00 or lower price range that is compatible with Windows XP, and is easy to install and understand.
Closed Thread
Results 1 to 1 of 1
i am the true King Of The Iron Fist
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 22:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 02:41 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 16:15 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 10:28
