i want to be able to capture some footage off of my Playstation 2, make a video, and put it on the web so what would i need to do that. i understand i need a capture card but i have no idea of what to look for, someone recommended a Matrox RT.X10 and it seems good but i have no knowledge whatsoever about Videocards i wouldn't know how to install it or undertsand it for that matter. i just want a capture card so i can hook up my Playstation 2 and capture some footage and put it on the web. i need one around the $600.00 or lower price range that is compatible with Windows XP, and is easy to install and understand.
i am the true King Of The Iron Fist
a capture card shouldn't be anywhere near $600. i just got a ati tv wonder ve for $40. installing it is not hard at all. i took the advice of some people on here and installed the Bt8xx (or something like that) drivers instead of the ati ones. BIG MISTAKE. every channel was messed up. some were all static. plus to see channel 10 i had to set the tuner to channel 11. channel 77 to 78. but channel 32 i had to set to 34. that was weird. i uninstalled those and installed the ati winxp drivers off their website and it worked perfect. i use powervcr ii to capture (captures directly to mpeg2) and they always come out great.
For web video, I would go with a cheap $50 TV tuner capture card. For high quality DVD video captures, go with an "analog to DV video" converter card or box.
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 22:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 02:41 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 16:15 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 10:28
