hey i never tryed to conver a xvid to vcd and i was woundering if you had to do the same process like dvix by extracting the audio..., or if you have to do it anyother way can someone tell me what i am suspose to do to convert an xvid
well i never had a problem with them b4..I just extract the audio wav in Virtual Dub, then go to TMPGEnc and add the A/V files there..
CCE wont be able to pick up the XVID tho..I got some error saying "COMPESSION NOT SUPPORTED" or something..
There is way tho to get passed that tho if u use CCE..U can download Koepis Xvid Pack from this site -- http://www.dawnload.net/video_software/codecs_and_filters/xvid.cfm
There is an option called FOURCC Changer, and u can change the XVID tags to DIVX, if whatever encoder ur using wont read Xvid Properly..
TMPGEnc doesnt have problems tho, so i just use that and never have to worry about changing the original tag..
Keep in mind its still XVID..Ur not converting it, just changing the tag as to fool the encoder into reading it as DIVX-AVI.. -
the main problem most people have with xvid is the audio is ac3 most of the time.
cool thanks. i just converted dumb and dumber which was a divx file and converted the wave file in virtual dub , i used the guide a www.vcdhelp.com/divxtovcd, but i still got a little out of sync any tips?
giftedretard,
I'm having the same problem, as well.. How do you "change tags" to DivX (from xvid, I assume..)??
I'm trying to convert avi files to DVD (mpeg2) and CCE keeps giving me error that it can't find proper 'decompressor codec'. Also, Media Player gives me the same error too..
Please advise.. thx. -
http://www.roeder.goe.net/~koepi/xvid.shtml
First link...comes with the FourCC changer
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 14:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 19:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
