I have downloaded an xvid movie, the quality is lovely but there is no audio. What should I do?
Download Gspot from the Tools section and use it to identify the required audio codec. Get the required codec, again from the Tools section, and install that. Problem solved.
"Art is making something out of nothing and selling it." - Frank Zappa -
You need the AC3 codec, the link is in the tools section.
I have just downloaded it and it works great, thanks alot for your help. Now I will try to encode it!!!
I'm looking for the same codec...but I haven't been able to connect to the link
does anyone know where else to go? -
Here is another AC3 codec version which works best for me becuz with it I can encode movies with AC3 directly from TMPGEnc without converting the AC3 sound to wave first.
http://www.divxsweden.net/program/filer/ac3codec.rar
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 13:15 -
Problem with convertion to xvid...
By zovx in forum Video ConversionReplies: 11Last Post: 11th Feb 2010, 07:43 -
MKVTools and Xvid problem
By Geiger9 in forum MacReplies: 5Last Post: 18th Jun 2009, 16:34 -
Problem with XVID
By s2dat in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2008, 12:25 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
