I'm having a werid problem on my computer. I don't know if it becuase I downloaded something or did anything but it won't let me restart or shut the computer off. What can be the problem?
When I go to start and click on shut down it doesn't do anything. The restart doesn't work either. I tired shutting it down with Alt+Ctrl+Del and still nothing. I have to take the power out to shut the computer.
Can anyone help me with this.
I also have another question about re-installing XP. Is there a way to just re-install xp while I still keep all my files and programs or do I lose them?
I have a link from Microsoft Knowledge Base about your problem and don't know if this would help you. Check out: http://support.microsoft.com/default.aspx?scid=kb;en-us;814761Originally Posted by AND1
With Windows 2000, I can keep my personal files in the system in OS re-installation. There is a R for repair using a WinXP disc. I think you need to re-install all of the post factory programs and upgrades. Just read your WinXP help and carefully check for options best for you.
I also suggest you backup your data including all your personal files into a CD or into another computer before any installation repair or clean re-install. Check out: http://support.microsoft.com/default.aspx?scid=kb;en-us;312368
Computer Won't Shut Down
By DarrellS in forum ComputerReplies: 5Last Post: 23rd Jun 2010, 00:51 -
How to shut down harddrives after 20 minutes
By mysts in forum ComputerReplies: 2Last Post: 20th Jan 2010, 02:19 -
A problem has been detected and windows has been shut down....
By gooberguy in forum ComputerReplies: 6Last Post: 10th Nov 2009, 16:11 -
Super converter shut down.
By dfisher052 in forum Video ConversionReplies: 0Last Post: 21st Mar 2009, 09:49 -
PC suddenly forces me to shut down
By Jeikobu in forum ComputerReplies: 15Last Post: 3rd Dec 2008, 19:18
