can I use DVD+R discs on my pioneer 105???
Results 1 to 13 of 13
The difference between +R and -R? Check here: http://www.anandtech.com/guides/viewfaq.html?i=118
"Art is making something out of nothing and selling it." - Frank Zappa -
Because it's + and Pioneer only handles -. I have no idea why would you want to use + for. + media is expensive that - media -- at least in USA it is.
dhluke -
Thee may look the same and feel the same but they're simply not the same. They are different formats and you have to get a drive compatible with both if that's what you want. I think Sony makes one.
I always hear people on this site saying how much cheaper -R/W is compared to the +R/W I live in the central US and and it is the +R/W that is cheaper and it is hard to actually find the -R/W. Does it just depend on the area I guess..
I live in the Midwest and the price for + and - are the same. But we have about 10 times more + then we do-.
Drew and Blacksmith if you check the internet for any discs it will be obvious which is cheaper.. www.meritline.com I thought this post was a yes or no answer..?
You 2 dont shop at best buy do ya? They have more + because they took sides early and were only selling + drives, they do carry - media but not many options.
But not + will not work in - drives. They only look the same because its a optical disk/dye format. Just like you can't read DVDs in a CD-Rom.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
