MIB
  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    MIB
  2. I did this movie about a month ago..it's simple. Just rip the entire main vob set to your hard drive, in your case, your better off ripping all files to the HD, then using IFOEdit to strip out extra audio tracks such as director's commentary, spanish, etc. Just keep the English track if that's the one you want and let IFOEdit do its job. I'm not sure what you are doing, but I don't remember there being seperate vob sets, so you are doing something wrong. Just do what I'm saying with IFOEdit and you will be fine.
  3. I used dvd decrypter on the region 2 disc and I'm pretty sure it selected the right files. Plus, they were less than 4.3 gig so it fitted on one dvd-r with no messing about.
  4. I have just copied MiB2 from DVD onto VCD as I don't have a DVD burner (yet!!). You're right, the file size for the movie is about 3.5 Gigs (with all the extra bits'n'pieces kept in the vob files). One thing I did notice was that Smartripper couldn't rip the whole movie in one go, it kept overwriting the first vob with the last one! So I ended up having to rip as chapters - ripping chaps 1 - 27 into one folder and chapter 28 into a seperate folder, then re-naming chap 28 and adding it into the existing 27 chaps for the rest of the film. I've never experienced this before on any DVD. Maybe you're having similar problems ripping for DVD.
