After I am using DVD2AVI to separate video and sound from DVD file .vob but after finished it only shows video file (.m2v) but no audio file. Please help, thank you.
Make sure in the DVD2AVI menus, under AUDIO, you select AUDIO | TRACK NUMBER | TRACK 1
This is usually the track you want. For AUDIO | CHANNEL FORMAT, select 'Auto Select'. Under AUDIO | DOLBY DIGITAL, select 'DEMUX' if you want AC3/MP2, or select DECODE if you want to resample you output audio from 48Khz to 44.1Khz (this option is also under the AUDIO menu).
You can select FILE | SAVE PROJECT to quickly generate your audio file, and a D2V file. This way, you won't have to save your AVI again.Impossible to see the future is. The Dark Side clouds everything...
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 02:01 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
How to merge audio file(mp3) and a video file (flv)
By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 00:15 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
