Hi,
I've got a Sont IP7 camcorder, it uses the micro mv tape format.
I wish to convert my tapes to a CD-R so that I can watch them on my dvd player without any quality loss.
When I export the video clips to my pc (using the provided MovieShaker software) it is stored as a mmv file.
I am told this is a MPEG2 file but a different type of MPEG2 is needed to create a SVCD.
Unfortunately I only have a CD-rewriter not a DVD-writer.
I have used a piece of freeware called mmv2mpg.exe which is supposed to convert the files to the correct type of mpeg2, but when I create the SVCD it plays back on my DVD player, but there is no picture and no sound - just a blank screen.
I have used different burning software, Nero, VCDeasy, etc and I have created VCD's in the past.
My DVD player is the nextbase DMV4 - which should not be the problem.
Can anyone help me, someone out there must have micro mv tapes they wish to put onto CD and hopefully they've succeeded !
You can always try opening the file in DVD2AVI, and saving it as an AVI (you can convert AVI to anything), or frameserving it to an MPEG2 encoder (like TMPGenc, or CCE). You can find all of these in the TOOLS section to your left.
Impossible to see the future is. The Dark Side clouds everything...
Sumvision Cyclone Micro 2+ menu flickers!
By Cieran in forum Media Center PC / MediaCentersReplies: 0Last Post: 24th Nov 2011, 20:44 -
Sony PMW-EX 1 and Redrock Micro M2
By B-Twien Bytes in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2011, 04:00 -
Want to compress to micro file size
By sum_guy in forum Video ConversionReplies: 6Last Post: 24th Feb 2011, 19:39 -
Sony Micro MV camera?
By lordsmurf in forum Capturing and VCRReplies: 2Last Post: 21st Mar 2010, 19:38 -
Can't get Norwood Micro dvd r-w to function
By Raptorcat61 in forum DVD & Blu-ray WritersReplies: 6Last Post: 21st Feb 2008, 10:43
