How do I go about doing this? Frameserving from VirtualDub, after the file has finished encoding in CCE the widescreen borders are gone so the whole image is stretched upwards.
Any help?
Yes, there are settings you can make but it will depend on what your source is and what you are trying to create (DVD, SVCD or VCD).legionpc: How do I go about doing this? Frameserving from VirtualDub, after the file has finished encoding in CCE the widescreen borders are gone so the whole image is stretched upwards.
Can you give more information?
You can usually get over this problem by separating and processing the audio on its own, then joining (mutiplexing) the two after encoding.AD421: i tried frameserving with vdub too but it gives me an audio sync problem -
yes i tried that but it still gives me the same resultYou can usually get over this problem by separating and processing the audio on its own, then joining (mutiplexing) the two after encoding.
You didn't say if you're encoding to SVCD or DVD (it makes a difference). SVCD has a DAR of 4:3. DVDs can have DARs of 4:3, 16:9 (rare) or be apomorphic (most common). Most newer DVDs are apomorphic, the video stream is encoded in the correct aspect ratio, then flagged.
You're DVD player reads this flag then adjusts the video on the fly as needed. If you have a standard tv, and the DVD is flaged 16:9 then it is letter boxed on the fly by the DVD player.
Now older DVDs often were letter boxed. That is the black bars were encoded as part of the MPEG video. These discs have a DAR of 4:3. However some groups still called this discs 'widescreen, letterboxed, special ed, etc' The key is NOT apomorphic.
Hope that helps. Tell us if you want to make a SVCD or DVD, and the source material and we can tell you more from there. -
this sorta has to do with a problem i posted about a few days ago, I am trying to encode to dvd video from an mpeg-1 file i captured from my tv card. I use virtual dub to cut the commercials and frameserve it, but the picture is tiny, its in an .mpv file format with no sound. any ideas?
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 20:52 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 11:10 -
Why do some Widescreen Movies still have black bars top and bottom?
By the_importer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Dec 2007, 09:09 -
getting rid of black borders from ripped widescreen movies?
By curt1sw in forum Video ConversionReplies: 12Last Post: 20th Oct 2007, 04:35 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
