I have a file that has a frame rate of 23.97 and I want to be able to play it on a ntsc dvd player. I'm using TMPGenc and I tried interlace and non-interlace with 3:2 pulldown and I got horizontal lines. Also what settings do I use when I have a pal file that has a frame rate of 25. And what do I do if I have a file that already has a frame rate of 29.97 do I just choose the dvd ntsc template in TMPGenc. I have read about frame serving and was wondering if that is what I need to do.![]()
For 23.976 fps -> 29.97 fps for DVD:
- Video tab:
"23.976 (internally 29.97 fps)"
"3:2 pulldown when playback"
- Advanced tab:
"Non-interlace"
Field order is not applicable and doesn't matter.
Do NOT check any filters that affect the frame rate or interlace.
PAL 25 fps -- I don't know.
Try TMPGEnc's project wizard (from the File menu) to sort out these things and then look at what settings it uses.
Frameserving shouldn't have anything to do with your frame rate issue.
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 16:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 11:02 -
horizontal lines in mpeg2
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2008, 18:05 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 20:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 13:06
