I am copying VCR to DVD via an MSI G3Ti200 ProVT128 and composite video. When I use a VCR tape I created on our camcorder, the output starts with a white horizontal band accross the video which goes away in about 5 seconds. If I use a store bought VCR Movie, the white bar stays.
I assume I'm fighting against some copy protection scheme. Is there a work around? Thanks for your comments.
if the msi card is a geforce you could try a different or earlier nvidia wdm driver. wdm 1.08 worked great for my geforce2. i had this problem also whilst using the latest wdm driver for my asus card.
You were right...i deleted the cature drivers and reloaded them from the original driver cd and presto...no more white band!!! THANKS
turn off/disable VCR On Screen Display for capturing
By lesleyjudy in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2021, 08:01 -
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 16:09 -
any way to capture 2 channel audio when VCR only has white plug?
By cduval04 in forum Capturing and VCRReplies: 6Last Post: 20th Jan 2008, 16:55 -
Capturing the blue screen with white DV tape graphic
By fusiblelinks in forum Newbie / General discussionsReplies: 5Last Post: 27th Jun 2007, 22:33 -
Vertical band moving across screen - DVD/HDD recorder
By wizbru in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2007, 03:20
