I have been working with this firewire device for some months, capturing my old VHS tapes (PAL) using iMovie and it works well, but now I have tried to capture a NTSC tape (VHS) and I loose the colour.
My video casette is pal but reads ntsc tapes in my pal tv. In my tv I see the colour, but not in iMovie.
Could someone help me?
Thank you.
You need to set iMovie in NTSC mode for NTSC video, and PAL mode for PAL video. Get the program "iMovieVSS" (http://www.versiontracker.com/moreinfo.fcgi?id=18239), which switches iMovie's video standard mode. This should fix everything, although you will need to recapture your video.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
It's not possible to capture PAL60 with the HDB (this is what you get, when you play NTSC tapes on PAL VCRs, which can play NTSC).This thing is called NTSC on PAL, but the colour carrier (4.x MHz) is different from NTSC (3.x MHz).
So, if you don't own a true PAL/NTSC VCR, you'll have to stay in PAL, if you want color.Some BT8... TV cards can be programmed to capture PAL60 in color (see DScaler and Avi-IO).
I know this, because I have the same problem. 8) -
Thank you for your answer. It seems that my problem is the colour carrier as you say because iMovie detect very well when I an in Pal or NTSC.
I didn't know this when recently bought my new video tape...and now I need a new video tape
Thank you again.
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 13:06 -
have unwanted borders from my dazzle captures
By andre477 in forum Capturing and VCRReplies: 3Last Post: 5th Apr 2011, 16:53 -
new Intel Sandy Bridge cpus
By kenmo in forum ComputerReplies: 19Last Post: 23rd Jan 2011, 12:48 -
Dazzle Hollywood DV Grounding Fix
By mk2000 in forum Capturing and VCRReplies: 6Last Post: 15th Apr 2009, 09:20 -
Adobe Bridge m2t files
By vegasarian in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2008, 10:39
