Page 2 of 2
FirstFirst 1 2
Results 31 to 32 of 32
  1. Originally Posted by mrbass
    If you don't care about menus and extras and just want to split the main movie to two dvd-rs (if it requires) it you can do it for free with dvdtoolbox. I myself would probably never split it to two dvds though.
    The latest version of DVDToolBox 0.12.0 is now crippleware, not freeware. The author now wants about $12.99 for it. Not a bad price, but still TOO MANY BUGS for it to be crippleware.
  2. [quote="thxkid"]
    5th If you use DVDxCOPY to burn with your resulting backup will not play on a XBOX and some PS2's
    You downsize DVDxCOPY before burning and use recordnow to burn you get perfect results in XBOX and PS2(if thats important).quote]
    That's odd, I have never had a problem with my modded Xbox or my friends unmodded Xbox. These were from Xbox launch and are fine.
    I have used DXC to burn also, so I know it works for me.
    Is DXC worth it????? Hold out for the Platinum version, it will have all of the features of IC7 (which I also own) and hopefully will do at least the same quality job.
