Is it possible to convert Dvix to DV in Virtualdub (or any other software)? I have tried in vdub but get the following error:
Cannot start video compression:
The source image format is not acceptable.
(error code -2)
Yes it is possible with a DVcodec that can create DV type 2 avi.
You must resize to the correct DV resolution 720x576 for PAL or 720x480 for NTSC (and also the correct framerate is needed). You may need to create black borders to fill up the resolution without distroying the aspect ratio. The audio should be with 48 kHz sampling frequency and not compressed (use PCM or wav audio).Ronny
Advice on DVIX/Avi dvd players
By aelfheah in forum DVD & Blu-ray PlayersReplies: 15Last Post: 27th Jan 2011, 16:48 -
dvix/xvid to dvd using ffmpegx???
By Jgarlich in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2009, 20:57 -
dvix to dvd using ffmpegx???
By Jgarlich in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2009, 19:26 -
DVD shrink vs DVIX video quality
By sportflyer in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2008, 20:31 -
Sound Problem During Playback (XVid, DVIX etc.)
By Pyrolisk in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 11:00
