Hello, I have probably read every post and used up my dvdrw as many times as one could trying to figure out the audio sync problem with Ulead Movie Factory2. I am trying to put a bunch of simpsons episodes on a dvd, but everyone gets out of sync about 1 minute into it. I have the do not convert compiant mpegs checked...I customized the template to mpeg audio 48000 hz and 224 kbps...But i dont know what im doing wrong. Im so frustrated it hurts..If anyone can help, please do, thanks
-Nick
I have used ulead dvd movie factory for 4 weeks as a trial. It makes basic but very clear DVD copies of my old VHS tapes/ dv camcorder. However I find that using its presets avoids problemss, For highest quality use the 8000kb or for still good quality but more room on a DVD change down to the 6000kps. Your audio syn prob may well be a problem in the original simpson files capture process. My PC has POWERCINEMA software to capture TV via cable/compositie or SVHS. It seems to record these perfectly, and when those mopeg files atre added to ULEAD DVD MOVIEFACTORY, and then burned at 6 or 8k the DVD plays perfectly.(on my toshiba DVD. When I capture using eg Ulead DVD Moviefactory itself, and then burn at 6 or 8K to my dvd, there is often sync problems. I have no idea why that is. Try using DVD MOVIEFACTORY only to chop up and burn the original files. use something else to capture the files in teh 1st place. sorry I cant be more technical. uSE A dvd rw UNTIL YOU GET IT RIGHT. saves coaster
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
