using mainconcept is there an option to split the movies like tmpge so i can burn or will it do it automatically like avi2 encoder ?
In the advanced settings final tab, there is option to enter split size, i usually select 790 mb for 80 min cd as it is not exact and can be a little under/over.
So if you use a bitrate calc you can fit on to however many discs you want
Was wondering if such a thing exists....WAN (Wireless USB connector)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2010, 03:53 -
Why is there no such thing as 60FPS above 320x240?
By Syclone0044 in forum Newbie / General discussionsReplies: 29Last Post: 28th Sep 2009, 14:22 -
The One Thing That Can Save HD DVD
By cracula in forum DVD & Blu-ray PlayersReplies: 12Last Post: 19th Feb 2008, 12:52 -
This blue paste thing
By vipertongn in forum ComputerReplies: 13Last Post: 6th Feb 2008, 07:03 -
Is there such a thing as DVD-RW DL disks?
By the_importer in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Dec 2007, 04:28
