I´m using TMPGEnc to try convert my divx movies to mpg so Ill be able to burn it into vcd but Something is wrong. when its finished the mpg file is over 2,6 gig and no sound on it. Im using TMPGEnc12a cause TMPGEnc12i wont open my divx movie. I only get a wrong message saying cannot open or unsupported, Works fine in 12a exept for the big files.
Well first the size is depends on the runtime of the source. The if you're using the standard VCD template that's 1150kbit/s. The size of the source does NOT matter.
As for why there's no sound that's a little harder. When you load the DivX in TMPGenc does a souce come up for both the video input and audio input? Can you play the file in media player? -
I get the box system video+audio checked in right. but how long should it take to convert the movie, it says between 4,5-6 hours for me and i have an Athlon 1,2 512 meg ram.
You can also frameserve the DiVX from VirtualDub to TMPGenc. You can even use some filters this way. If not set video and audio to direct stream copy.
Good luck. -
Had the same problem with converting divx to MPEG with TMPEGenc. 12j...
See my post in the conversion section of the forum....
Tried to convert Divx (Hannibal)to MPEG with TMPGEnc.
It's a movie in two parts..converting the first part took about 10 hours because TMPGEnc. kept on converting for hours when the movie was already ended...the last frame of the movie was in the 'viewer' for hours
After using "Merge&Cut" I had a good video MPEG-file but no audio....????
Everything looked OK, the audio source was listed
and the original source was:
MPEG-1 640x352 23,976fps CBR 1150kbps, Layer-2 44100Hz 192kbps..so I loaded it as a VideoCD(NTSCFilm)
can anyone help...
T.T...By the way..download the kristal studio codec..it helped me to open my divx/avi files in v. 12j..but first deinstall the codec on your computer.. -
Well i think i got it to work now when im converting 10th kingdom (4 divx cd
*ouch*)havent finished the first yet
. but the other one dont work. Could it be that it uses another decoder? 10th kingdom is just an ordinary divx but my Rocky III is named Divx-REQUiEM. or is it some ntsc versius PAL problem i could have? I only convert to PAL.
It worked, sound and every thing. pretty good quality to. lets see if I get trouble on cutting it to =).
HELP! Whats Wrong with My Video Clip!
By augustlow25 in forum EditingReplies: 6Last Post: 15th Sep 2011, 03:32 -
Whats wrong with this batch Mkv script?
By Animebuster in forum EditingReplies: 0Last Post: 21st Jul 2010, 03:59 -
Audio that use to play wont anymre. Whats wrong?
By UmmAddan in forum Software PlayingReplies: 1Last Post: 5th Jan 2010, 18:13 -
All was well ...then whats the hell wrong with the sound
By qwerty00000 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 26th Sep 2009, 05:39 -
Whats Wrong With This Forum?
By gealto2 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Jun 2007, 18:11
