I would like some recommendations on capturing in a format that I do not have to do too much re-encoding to place on a DVD-R. Does anyone have any suggestions on settings for ATI MMC or any other capture programs? I will be capturing from an S-video source coming off a DirecTV satellite system. I guess I am really trying to find a way to balance quality vs. ease of capture burn.
Thanks for any help anyone can provide.
ShadowAce
Download MMC 8(or 8.1 if you have DirectX9)it will make DVD compliant videos.If you are looking for a good video editing program you can capture and burn with I recommend Ulead VideoStudio.
www.ati.com/support/driver.html
www.ulead.com/vs -
ShadowAce.
Have a look at the link in my sig, capping etc. with the AIW.
There is a sample of video on the main page, the bitrate I use to get 6 hours is a bit low so if the video isn't high enough quality increase the bitrate - this will decrease the amount of time you will get on the disc. -
Hi MOVIEGEEK,
You sure of MMC 8.0 not 7.7.0.1. 7.7.0.1 is all I could find on Ati's site. -
MovieGeek:
As far as I know MMC 8.0 is for the 9xxx series of ATI's Radeon cards (not the 7xxx series.)
You mentioned 8.1. I know that is supposed to be for previous version ATI Video cards. By your post it sounds like it is available for download, now. Have you downloaded MMC 8.1, or seen a link to download it? If so please share the link with us. The only reference to MMC 8.1 I can find is in the FAQ Q14 here: http://mirror.ati.com/products/pc/aiw9700pro/faq.html#14 and it states MMC 8.1 will be available in spring. -
I meant MMC 7.7.0.1
hwoodwar,you are correct MMC8.0 is for 9000 series,that MulTView feature looks COOL I can dust off my old Wonder VE card and have Picture-in-Picture.
I've been hanging around rage3d.com too long,all the gossip has caused my brain to warp.
If you have any ATI questions go to this site(you can sometimes talk to an ATI rep.):
www.rage3d.com
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11
