which is the best ripping programme for dvd to dvd-r
1 smartripper
2 dvd decripter
just a straight answer please i will get the one with the majority of posts
Results 1 to 20 of 20
DVD Decrypter is the 'easiest' choice because it does a lot more than smartripper. It does everything smart ripper does but also:
You can rip a DVD-5 image, then burn it.
You can see the region, total disc size, layers, etc.
You can burn any iso image file
Scan media
etc.
However, there are some discs I can't rip with DVD Decrypter and i have to use smartripper. Given that both are freeware I'd get both
dvd decrypter
SmartRipper is good, well designed and free.
DVD Decrypter is AMAZING, well designed, and free, and will do a lot that SmartRipper can't.
But as with any program, it's what you find easiest / most comfortable that will be the "better" program.
Download them both, use them both and judge for yourself. They're small, easy to use, and free.
- housepig -
That's not true, I use Smartripper when I want to strip .m2v and .ac3 files from .vob files on my hard drive (used quite often). DVD Decrypter won't do that, it only will rip from a DVD-ROM drive.DVD Decrypter is the 'easiest' choice because it does a lot more than smartripper. It does everything smart ripper does but also:
rhuala -
Rhuala -
mea culpa... I've never done that with SmartRipper, so I didn't think about that feature.
- housepig -
it will if u enable stream processing and demux it
Originally Posted by rhuala2 -
DVD Decrypter is by far the better ripper. dose the same thing smart ripper dose and more. so smart ripper can strip out the ac3 and m2v file form the hard drive. big deal if some one did a poll if they could only have one ripper what would it be? i bet they would be atleast 90% would want DVD Decrypter.
DVDDecryptor. It's awesome for do 'Episode' backups, among other things.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
For me Smartripper is better. This is because I often strip m2v and ac3 streams.
I have read a few people claim that Decryptor does MORE things that Smart Ripper. That isn't true. It may do "things" that Smart Ripper won't in certain situations, but Smart Ripper does things that Decryptor doesn't. Just to name a couple of things...Decryptor seems to be more sensitive to certain things and not rip certain disks, while Smart Ripper almost always will handle business. One thing imparticular is when trying to rip an RW disk that isn't formatted. DVD Decryptor just WON'T RIP IT. Plain and simple..it will tell you that the disk is NOT formatted and won't allow you to rip.You can rip a DVD-5 image, then burn it.
Scan media
etc.
That sucks when I'm testing out things on my RW which of course is NOT formatted. However, SmartRipper doesn't give you that message and will rip up that RW just like any other disk. I can give other examples but to say that Decryptor is more versatile is innacurate. To say that BOTH programs are INCREDIBLE and could EASILY be offered for a price, right along with IFOEdit and DVD2SVCD, DVD2DVDR, PULLDOWN, etc...well, that's an accurate statement. Both programs should be used to meet your need at that time. Both are EXCELLENT programs like most others in the tools section of this forum. -
think thats a personal problem i have no problems ripping from a rw dvd using dvd decrypter.
red lion:
gui or G.U.I. pronounced "gooie" (rhymes with Louie) stands for graphic user interface, I think. -
I didn't say I had a problem ripping in Decryptor with an RW, I said Decryptor WON'T rip an UNFORMATTED RW. Unformatted being the key word there.think thats a personal problem i have no problems ripping from a rw dvd using dvd decrypter.
ok i have decided to use this one DVDDecryptor i have a SONY DRU-500AX firmware 2.0 (january 2003 build) when i use DVDDecryptor it reads at 2x how do i change this to 4x which i belive my writer to support
it says for time 45 mins is this normal(tombraider 4.6gig (i think)
{edit} yes its 2 layers just checked {edit} -
Red Lion -
many dvd drives (and from what I've read, MOST Sony drives) are locked at 2x when ripping from a commercial dvd.
by contrast, I have an old 8x generic dvd-rom drive (Raito? something like that) and DVD Decrypter can get the rip speed up around 6.5-7x.
So you might want to look around for a non-Sony dvd-rom - apparently some Lite-On drives can get fast rips going.
but if you stick with the Sony, you are going to be locked at 2x.
- housepig -
At the moment i have only 2 drive bays i took out a dvd rom to get the sony in and i need my other bay for a liteon cd-rw
i know the sony will record cd-rw but it wont do efm encoding...
so im stuck at 2x unless there is a way to change it -
Haha it's amazing how people can fight for simple things...
Both programs are excellent and free!!!
dhluke
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
