  1. Okay...i'm trying to backup a DVD that I have but when i try it says it is CSS copy protected. Is there any way around this? I'm trying to put the DVD from the Disk to the harddrive. Is there a program i can use first to get rid of the protection or anything??
    any help would be appreciated. THanks!
  2. I tried using DVD Decryptor to get rid of the protection. But i don't know how to change it to the proper file type for Instant Copy to use? Help please!
  3. Rip the whole movie to your hardrive and use it as input into Instantcopy.
  4. I ripped it using DVD Decrytor and it works fine but comes out as a .rar file. But when i try using it as a source for Instant Copy, it says that it isn't an acceptable file type. What do i do next???
    is there a program like instant copy that doesn't have protection on it??
  5. You have to rip in DVd Decryper in file mode. Selecting all the files.
  6. If you are having trouble follow this guide look at the instantcopy part.
    https://www.videohelp.com/forum/userguides/141024.php
