For some reason under windows 2000 and the DRU500AX you can not burn Khpermedia or Memorex DVD-R. I test it with service pack 3. With windows 2000 I can only burn certiied media. I format the drive and install windows XP. Kpermedia now work fine and Memorex. If you are having problem's with the DRU500AX install windows XP and have it set to master. DRU500AX does not work that well under windows 2000. I got a little halp at
http://forum.doom9.org/showthread.php?s=&postid=274499#post274499
To fix DRU500AX to burn Khpermedia you have to update to
NERO 5.5.10.15a any older nero's will have problem with windows 2000 burning khpermedia or Memorex. With Windows XP nero 55107 work's fine also but not on windows 2000 only. NERO 5.5.10.15a will work good with windows 2000 -
Intersting.
Have burned about 8 Memorex DVD-R { Retailed box of 10 } without problems with f1.0g + Nero 5.5.10.7b on Windows 98SE. But under W2k any thing is possible. -
Khpermedia can only be burned at 2X with windows 2000. XP When I had it install burned fine at 1X. You must use the newest version of Nero with the DRU500AX
This is the last update I thought I fixed the DRU500AX problem. But it seem's some time's I can burn Khpermedia and Memorex DVD-R. If you have the DRU500AX the newest version NERO is the best in windows 2000. XP 55107 work's as good as the newest version. This drive also work's best when set to master. Also this drive for testing seem's to work fine with USB or firewire. I'm bring this drive back I gave it one last chance. If you want to burn DVD-R Pioneer or Cendyne. If you want to burn DVD+R I would stick with HP. I have a Pioneer AO4 and it can burn hkpermedia and Memorex ever time with out any problem's
Can this blend be fixed?
By alcOre in forum Newbie / General discussionsReplies: 8Last Post: 20th Jun 2009, 13:02 -
Can vertical oscillation be fixed?
By davexnet in forum Video ConversionReplies: 11Last Post: 19th Feb 2009, 20:11 -
Memorex DVD+R DL 8X Media Not Being Read
By Surfmaster in forum MacReplies: 10Last Post: 12th Nov 2007, 12:59 -
by looking at this picture can it be fixed?
By effects in forum RestorationReplies: 4Last Post: 27th Aug 2007, 15:01 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
