I am new to this, and i have been able to use virtdub in the past to create a wav file to use in tmpge. i have since tried to create a wav file from this file and it says that "no audio decompressor could be found to decompress the source audio format". Could someone please walk me through how to make this file into a wav so that i can use it in tmpge.
thanks
Below is some info from the file that may be useful
Frame size: 640x272fps, 23.976fps
decompressor: divx mpeg-4 low motion
sample rate 48000
channel 5(stereo)
compression unkown tag 2000
any help would be much appreciated
[/quote]
Highlander -
can you play this file and hear audio?
It looks from the error message that it uses an audio codec that's not present on your system.
I believe there was a news post recently dealing with how to identify codecs in video files, I'm not sure if they covered audio codecs or just video, but you may wish to search for it.
Otherwise, can you give some more detail on the file? Is this something you captured? Where did the file come from?
- housepig -
Originally Posted by highlander22
First, download and run Gspot from the Tools section. It will tell you what codecs are required for this file and if you have them. It looks like you have AC3 sound (Dolby surround) in this file and you first need to get the AC3 codec and install it, try a google search or look in the Tools section again.
I use Goldwave to extract AC3 sound and to convert to Wav. It's simple: start Goldwave, load your AVI, select Save As and you're done. There are other programs to convert AC3, Headac3he and AC3tool to name two. You'll find the steps to use use either of them here: https://www.videohelp.com/forum/viewtopic.php?t=91588"Art is making something out of nothing and selling it." - Frank Zappa -
zippyp,
I ran gspot, and this is the audio codec that it said that i needed. (ac3 (0x2000) "Dolby Laboratories, Inc" ) Do you know where i can get it?
I also tried gold wave with no success
thanks -
You'll find it in the Tools section under codecs. Once it's installed you can then use Goldwave, or you can use Vdub and either Headac3he or AC3tool. For the second option the guide is here: https://www.videohelp.com/forum/viewtopic.php?t=91588
How do I get the exact file size I want with Virtual Dub ?
By Simmons in forum Video ConversionReplies: 3Last Post: 21st Jul 2011, 01:32 -
Virtual Dub delogo output file help
By Rogert in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2011, 12:25 -
Help creating a virtual dub mod script just like auto gk does
By viraco in forum Video ConversionReplies: 4Last Post: 3rd Mar 2010, 09:42 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 13:35 -
how to batch file in virtual dub?
By warlock110 in forum Video ConversionReplies: 2Last Post: 17th May 2007, 00:56
