I have a bin file but no cue. I think you can make a cue file in note pad but I'm not sure how to do it. If someone could help me on this I'd appreciate it. Thanks!
Do you know if this is a bin of a VCD??
If it is, the best way is to probably use VCDXRIP to extract all the files and PBC settings off the bin and then immediately use VCDXBUILD to rebuild the VCD into a CUE/BIN image.
This way, you can retain any menus or other things which may have been included in the original disc.
Regards.
Michael Tam
w: Morsels of Evidence -
I have found that with Nero 5.4 you can burn just a .bin file. You run Nero, and close the wizard. Then select "burn image". Instead of selecting a cue file, you select your .bin file. This opens up a "Foreign image box"
that should have everything you need already selected-just burn. (I learned this because Nero reads cue files wrong-a single disc vcd file would be read as two files of equal length-and there would not be enough space on your disc)
it's definitely a bin of a movie...is it a DivX? Is it a VCD? Is it a SVCD...etc? I have no clue. Is there any way to tell?
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>On 2001-09-08 23:09:15, Hollywood004738 wrote:
that should have everything you need already selected-just burn. (I learned this because Nero reads cue files wrong-a single disc vcd file would be read as two files of equal length-and there would not be enough space on your disc)</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
well, if you do just burn the .bin file w/o making use of the index marks contained in the .cue file, then you'll end up with a 1-track only (S)VCD...
which is surely not compliant... whether it works on your equipment will be a matter of failure tolerancy... but be sure that some playing device may have problems with it
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
