Is it possible to modify the information shown by a utilility, such as DVDInfo, on a new DVD-R's pre-recorded leadin? If this is feasible, then this would appear to offer an alternative to modifying the firmware on drives such as the Pioneer A05 to defeat the internal list of "ok" software. Just edit in a manufacturer leadin that the A05 likes.
No, it can't - it's "etched" into the stamper that makes the pre-grove that the writer tracks like it is with CD-R's, I think you will find.
There are some hacked firmwares out there that will allow you to write at higher speeds on any media, but there's such a variance in quality out there at the moment that I personally don't risk it.
Converting Media Center Cablecard recorded shows
By pcostanza in forum Newbie / General discussionsReplies: 5Last Post: 19th Apr 2011, 08:44 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 18:45 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 23:06 -
Streaming Live Video with a pre-recorded video
By mmanor in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2009, 03:33 -
Where are media center recorded tv files stored on C:?
By galactica in forum Media Center PC / MediaCentersReplies: 2Last Post: 11th Oct 2007, 18:13
