Hello all!
I am having problems viewing a backed up DVD-R on a Denon DVM 3700 player. It plays fine for the first 45 min but then it starts to skip.
My question is when you leave out the Audio_TS file, does it (if you happen to have the wrong DVD player) cause the entire DVD to be unplayable or is it possible for some parts of the DVD to play and others not to play. I am asking this because I am wondering by adding the Audio_TS file, maybe I can get the DVD to play properly on the Denon. Any other suggestions would be appreciated (other than buying a new DVD player).
Did you put a sticky label on it? Those often cause playback problems.
DVD from .mts file with "combing" effect.
By HF20_user in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2009, 15:28 -
AUDIO_TS folder
By siluet in forum Newbie / General discussionsReplies: 14Last Post: 10th Oct 2009, 08:00 -
AUDIO_TS file is empty
By LaNoche in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2009, 20:35 -
Russian doll effect of dvd file
By cyflyer in forum Software PlayingReplies: 1Last Post: 1st Mar 2008, 20:31 -
No Audio_TS files?? HELP!!
By onlyoneman in forum Authoring (DVD)Replies: 5Last Post: 8th Jan 2008, 12:19
