I am unable to make a VCD compatible MPEG out of certain XVID and DIVX files with VBR audio. On occasions with paticular video files it does work by extracting audio with VirtualDub then encoding with TMPGENC as normal; however most of the time the VBR audio which I extract with VirtualDub matches not with the video file - the audio file is actually longer than the original video file whence it came...
Is there any way in which I can solve this problem?
Thankyou![]()
Try using goldwave (www.goldwave.com) to extract the audio. This sometimes works. If the length is still incorrect you can also use goldwave to stretch or shrink the audio as required.
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
Converting VBR avi Xvid/divX to wmv9
By surfmonkee in forum Portable VideoReplies: 4Last Post: 17th Nov 2008, 02:54 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 15:51 -
Joining Xvid files with MP3 audio (VBR) without loosing synch?
By fk in forum EditingReplies: 6Last Post: 31st Jul 2007, 19:19
