Closed Thread
  1. Can someone PLEASE help me?
    I try to make my own DVD with DVD Maestro....
    but If I importing my subtitle file ( .STL )...
    The time line is not correct anymore!!
    DVD maestro change it!!!
    But if I check (without dvd maestro) the Subtitle file...the Timeline is correct!
    Can anyone help this
    -Glock-
  2. Can nobody help me????
    PLEASE...can someone help with this problem?
    I search almost the internet globe to find it...but no luck...
    -glock-
  3. Probably because we can't figure out what you're asking - I certainly don't know what you mean when you say it "changes" the timeline.
    The only issue I know with importing subtitles is that Maestro assumes "drop-frame" timing, so you have to play a game or two with NTSC videos to keep the subtitles in sync - but searching the globe (or even just this forum) should have found several posts on that topic.
  4. VidGuy,
    Thanks...but still I try to make a PAL movie...
    First I sync (of cours) my (dutch) subtitle with the movie LORT Two towers...
    Than... when I import it in DVD meastro...Meastro change my time line , so now my subtitles are NOW OUT OF SYNC !!!!
    So CAN anybody explain WHY !!!!!!
    almost finish my movie... if the SUBTITLES WORKS FINE !!!
    anyone?
  5. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Do not discuss warez.
