  1. Im using showbiz to re-enocde an .avi to .mpeg but the picture is upside side down once it is finished.
    Can anybody suggest a solution??
    avi
  2. Hmmm, I had a similar problem in mainconcept and it turned out I needed to install ffdshow which is a directshow filter the encoder relies on...maybe this will solve your problem...
  3. I had the same problem and there are several solutions:
    1.-Try to encode it with tmpenc
    2.-Try to encode it with mainconcept
    3.-Open it with Vdub and apply "flip vertical" filter and then encode it with the program that had flipped the image before
    Let me know
  4. if you used nero to convert and burn then thats the prob nero is naff for conversion but good for burning, use tmpenc to convert
