  1. I've made a vcd but the audio on it vanishes if i try to fastfoward or rewind the movie. To reestablish the sound i must play the file from the begining. HELP!!!!
    Thanks from Brazil!!!!
  2. Trya pausing the movie and then pressing play. This works for me when this happens.
  3. You mean after the audio is gone? Ok, iŽll try then i come back here...
  4. Thanks for your tip!!! I've tryed pausing, but it didn't worked. Then i tryed stoping but when i start the movie from the vcd menu, the resume function does not work. So i discovered that starting the movie by selecting it's number instead of entering the menu, enables the resume function. This way, stoping and resuming really reestores the audio! Just for the record, my dvd-player is a Pioneer DV-333.
    But i still wanna know wy this is happening with this specific file?!
