Sorry but i have read all about bad frames and Virtual Dub but I can not find this option.
Where's the option to scan for bad frames in Vdub?
I have downloaded the pack of VDub, VdubAc3 and Vdub Mp3 but I could not find this option
Am I a stupid?
look under the video stream heading in VDub and at the bottom is "Scan video streams for errors"
VDub then marks bad frames as "masked." Does this exclude them from subsequent direct stream and/or full processing audio and video extractions? Or should the masked frames be manually deleted?
The vdub_mp3 will say "check video for freezes". Choose this and v-dub will scan for bad frames. When it finishes you will get a message saying it is finished scanning for bad frames. You must then get the list of bad frames from a bad frame log vdub creates and manully delete them yourself. Vdub does not delete them for you when it scans, it only creates a log of which frames are bad.
Oh Thanks !!!!
I thought I was going crazy !!
I've got AC3, Mp3 and the normal version of Vdub but I couldn't see this option.
So "scan for bad frames"= check video for freezes ?
I can only do it by this Mp3 version? -
Which version of Vdub you should use depends on your source file.
In regular Vdub, after you have scanned for bad frames (under the video tab), set both audio and video to direct stream copy and then save the Avi. All "masked" frames will be deleted in the process.
In Vdub-MP3 you must edit out the bad frames yourself. Here's how: https://www.videohelp.com/forum/viewtopic.php?t=142555
Hope that helps."Art is making something out of nothing and selling it." - Frank Zappa
I've got a choice between clipping or bad sync, need a third option
By Peter84072 in forum Capturing and VCRReplies: 6Last Post: 24th Jun 2011, 12:03 -
VDub and ffdshow: Encoder option empty for mpeg4 (Win 7)
By nbarzgar in forum EditingReplies: 3Last Post: 8th Jun 2011, 13:32 -
Problem with philips dvp 642/37 after choosing progressive scan option.
By vinland in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2010, 19:21 -
[Solved] where is RDO for B-Frames option ?
By Ahmed28 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2008, 04:50 -
Letterbox/Pan-Scan - Encoding or authoring option?
By ecc in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2007, 01:40
