Hi I burnt a music dvd with a concert on it and it automatically played on my dvd, which suprised me.
Anyway, there is a 1-2 second delay when the I hear the audio, the guy singing is behind the audio coming out!!
Can someone tell me how I can speed up the footage to match the audio or perhaps slow down the audio somehow to the footage as it looks like the guy is mimeing.
Hi
before you start adjusting audio try looking up your DVD player elsewhere on this site to see if there are any fixes or workarounds to cure the audio sync.
I had a cheapo SM 2500 with the same problem. VCD was the same as yours, SVCD not as bad. Changing the audio settings made it a lot better. A firmware upgrade from the manufacturer cured it altogether.
davros
Audio to video delay value on a DVD
By nic2k4 in forum EditingReplies: 20Last Post: 7th Dec 2011, 03:06 -
DVD Flick Audio Delay
By sambat in forum Video ConversionReplies: 0Last Post: 15th Jan 2011, 13:41 -
Can you delay the start of the video on a DVD?
By rayden54 in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2010, 08:53 -
Is there a blueray player with audio delay function on the market?
By Patrice1981 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 21st Sep 2009, 09:15 -
Audio Delay on DVD
By JOHNTOUPS in forum AudioReplies: 0Last Post: 25th Feb 2008, 20:41
