  1. Member videocheez's Avatar
    Jan 2003
    I have been following doom9's avi to dvd guide using CCE and after I finish encoding I load the new mpv file into spruceup and i receive an invalid frame rate error. Any suggestions. Should I multiplex the mpv with the ac3 file before trying to author the dvd?
    thanks in advance,
    This is so much fun!
    Jan 2003
    Is your source 23.976fps??
    You may have forgotten to run Pulldown.exe on the file
    8)
    "I´m not popular enough to be different"
  3. Member videocheez's Avatar
    Jan 2003
    Forgotten, I never new about pulldown. What is it going to do to my file?
    Thanks in advance,
    Jan 2003
    Yes forgotten!! It is mentioned in the CCE guide at doom9.
    Pulldown will change the framerate from 23.976 to 29.97fps
    8)
  5. Member videocheez's Avatar
    Jan 2003
    Thanks for the tip. Now I dowloaded pulldown but I don't know how to run it. When I click on it a little DOS window opens and closes before I can even see it. Do you if there is a GUI for pulldown.
    Thanks in advance,
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    http://guiguy.wminds.com/downloads/pulldownbatchfe/
    (<---click on the tools here to left for toools....)
