I use VCDEasy to burn VCD's and XSVCD's but when I tried to burn an XVCD, this is what I get:
[Internal Xml Generation]
Internally computed XML generated successfully: "C:\temp for me\videocd.xml"
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `VIDEOCD'
changed publisher id to `VCDEASY_V114'
changed application id to `CDI/CDI_VCD.APP;1'
changing 'relaxed aps' to 0
adding pbc (Selection-000/2)
adding pbc (Selection-end/3)
sequence count 1
adding sequence #0, C:\pvcrwork\352x480_mpeg1_3M.mpg
pos != buflen (2322 != 2324)
mpeg scan: pack header code (0x000001ba) expected, but 0x01ba2100 found (buflen = 2324)
bad packet at packet #1 (stream byte offset 2324) -- remaining 629230735 bytes of stream will be ignored
Next time, let VCDEasy analyse the MPEG files to have this warning before...
pts start offset 0.223000 (max pts = 0.223000)
playing time 0.000000
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
mpeg stream shorter than 75 sectors
sequence items should contain a motion video stream!
pbc: psd size 32 (extended psd 56)
iso9660: highest alloced sector is 257 (using 300 as isosize)
writing track 1 (ISO9660)...
writing track 2, MPEG1, UNKNOWN (0x0/0.00fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
MPEG packet statistics: 1 video, 0 audio, 0 zero, 0 ogt, 0 unknown
writting post-gap ('leadout pregap')...
finished ok, image created with 676 sectors [00:09.01]
[CDRDAO Disk Info]
Cdrdao version 1.1.7
ASPI: C:\WINDOWS\SYSTEM\WnAspi32.dll
0,1,0: MATSHITA CD-RW CW-7585 Rev: 1.04
Using driver: Generic SCSI-3/MMC - Version 2.0 (options 0x0000)
That data below may not reflect the real status of the inserted medium. Reload the medium in this case.
CD-RW: YES
Total Capacity: 74:58:00 (337350 blocks, 658/756 MB)
CD-R medium: CMC Magnetics Corporation
Short Strategy Type, e.g. Phthalocyanine
Recording Speed: 0X - 4X
CD empty: YES
[CDRDAO Write]
WARNING: During writing you should avoid to open the Windows Explorer and similar tools
WARNING: CDRDAO does not lock the recording device so that all access action from the Explorer will lead to a failure of the recording process.
WARNING: Track 2: Length is shorter than 4 seconds.
ERROR: The toc check function detected at least one warning.
ERROR: If you record this toc the resulting CD might be unusable
ERROR: or the recording process might abort with error.
ERROR: Use option --force to ignore the warnings.
ERROR: Toc file "C:\temp for me\videocd.cue" is inconsistent.
ERROR: Note that CDRDAO troubles are often related to the use of an inadequate driver...
ERROR: You may have a bad CDRDAO driver in the CDRDAO settings page.
"there is a problem with your sound hardware." error message
By arconreef in forum AudioReplies: 1Last Post: 8th Nov 2010, 14:58 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Can somebody explain the problem with this dv footage.
By Aarzoo in forum RestorationReplies: 8Last Post: 18th Jul 2008, 09:28 -
error while encoding, someone explain
By arabian in forum SubtitleReplies: 3Last Post: 19th Jan 2008, 07:42 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
